Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Krups F203 Coffee Grinder Motor Replacement
Ce dont vous avez besoin
    1. Krups F203 Coffee Grinder Motor Replacement, Base Plate: étape 1, image 1 de 1
      • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
      Demander à FixBot
      Ajouter un commentaire
    2. Krups F203 Coffee Grinder Motor Replacement: étape 2, image 1 de 3 Krups F203 Coffee Grinder Motor Replacement: étape 2, image 2 de 3 Krups F203 Coffee Grinder Motor Replacement: étape 2, image 3 de 3
      • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
      • Try not to break these clips as this will cause structural integrity issues upon reassembly
      Demander à FixBot
    3. Krups F203 Coffee Grinder Motor Replacement: étape 3, image 1 de 2 Krups F203 Coffee Grinder Motor Replacement: étape 3, image 2 de 2
      • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
      Demander à FixBot
    1. Krups F203 Coffee Grinder Motor Replacement, Detach Trigger Button from Base Plate: étape 4, image 1 de 1
      • The trigger button is held in with light tension clips. Gently pry them back to release.
      Demander à FixBot
    2. Krups F203 Coffee Grinder Motor Replacement: étape 5, image 1 de 2 Krups F203 Coffee Grinder Motor Replacement: étape 5, image 2 de 2
      • Remove the white trigger.
      Demander à FixBot
    3. Krups F203 Coffee Grinder Motor Replacement: étape 6, image 1 de 1
      • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
      • Be sure to reference the how to solder video posted to the device page
      Demander à FixBot
    1. Krups F203 Coffee Grinder Motor Replacement, Motor: étape 7, image 1 de 1
      • Desolder remaining contact point from the plug cord
      Demander à FixBot
    2. Krups F203 Coffee Grinder Motor Replacement: étape 8, image 1 de 2 Krups F203 Coffee Grinder Motor Replacement: étape 8, image 2 de 2
      • Using a Phillips screwdriver, remove the two screws holding the motor in place.
      Demander à FixBot
    3. Krups F203 Coffee Grinder Motor Replacement: étape 9, image 1 de 1
      • Remove the motor from the shell.
      Demander à FixBot
8 autres ont terminé cette réparation.
Ian Hancock
Membre depuis le 10/22/14
432 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 4-2, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 membres
48 tutoriels rédigés
8 commentaires de tutoriel
thank you so much
Nikolai Podrez - Réponse Partager
Doesn’t seem to apply to the Type 203. It looks different.
rpoland - Réponse Partager
The first photo of the bottom plate is too dark to show details. I have type 203 B Made in France and the clips didn’t budge without first breaking/stretching the thin outer walls of the base plate. No need to remove the wires. With mine, you have to turn the bottom shaft of the motor with a screwdriver (counter clockwise as usual) while holding the blade stationary which unscrews the blade from the motor enabling you to remove the motor after the two phillips screws are removed.
seeley6 - Réponse Partager
Hi Ian!
Nice explanation!
Can you provide a close up of the spudger that you used for opening the bottom plate?
I want to use the correct one, so I don ´t break that aged plastic cover.
Bengt
Yngve Lien - Réponse Partager
Where does one get the replacement motor?
Andrea Garrity - Réponse Partager
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 28
30 derniers jours : 135
Total : 30,596
