Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Sometimes, the plug or cord attached to the Krups F203 coffee grinder is defective. This guide will tell you how to replace the cord.
Pièces
Aucune pièce spécifiée.
  1. In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
    • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
  2. Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
    • Try not to break these clips as this will cause structural integrity issues upon reassembly
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate. Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
    • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
  5. The trigger button is held in with light tension clips. Gently pry them back to release. The trigger button is held in with light tension clips. Gently pry them back to release.
    • The trigger button is held in with light tension clips. Gently pry them back to release.
  6. Use the soldering iron to remove the existing solder.
    • Use the soldering iron to remove the existing solder.
    • Be sure to reference the how to solder video posted on the device page.
Ian Hancock
Membre depuis le 22/10/2014
396 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 4-2, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 33
Total : 1,865
