Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Krups F203 Coffee Grinder Trigger Assembly Replacement
Ce dont vous avez besoin
    1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Base Plate: étape 1, image 1 de 1
      • In each of the four rectangular slots on the bottom of the device, there is an E-shaped clip.
      Demander à FixBot
      Ajouter un commentaire
    2. Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 2, image 1 de 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 2, image 2 de 3 Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 2, image 3 de 3
      • Wedge the spudger between the flat side of the E-clip and the outside wall of the slot. Then, loosen up the clip by prying it inward with the spudger.
      • Try not to break these clips as this will cause structural integrity issues upon reassembly
      Demander à FixBot
    3. Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 3, image 1 de 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 3, image 2 de 2
      • Work your way around the four clips, loosening each a little at a time. Eventually, all four clips will be loose enough to remove the base plate.
      Demander à FixBot
    1. Krups F203 Coffee Grinder Trigger Assembly Replacement, Detach Trigger Button from Base Plate: étape 4, image 1 de 1
      • The trigger button is held in with light tension clips. Gently pry them back to release.
      Demander à FixBot
    2. Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 5, image 1 de 2 Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 5, image 2 de 2
      • Remove the white trigger.
      Demander à FixBot
    3. Krups F203 Coffee Grinder Trigger Assembly Replacement: étape 6, image 1 de 1
      • Desolder the contact points between the trigger button and the red wire and also where the plug attaches to the trigger button
      • Be sure to reference the how to solder video posted to the device page
      Demander à FixBot
2 autres ont terminé cette réparation.
Ian Hancock
Membre depuis le 10/22/14
432 Réputation
3 tutoriels rédigés
Équipe
Baylor, Team 4-2, Williams Fall 2014 Membre de l'équipe Baylor, Team 4-2, Williams Fall 2014
BU-WILLIAMS-F14S4G2
3 membres
48 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 15
30 derniers jours : 60
Total : 6,233
