Introduction
To get to the speaker you're going to have to go in past the motherboard and do some soldering work, which will require a little bit of finesse. Replacing the speaker should fix any issue of sound coming out of the Kurio 7.
Ce dont vous avez besoin
Use a plastic credit card, or other thin object, to separate the battery from the screen.
Carefully set the battery aside.
Pull the wires off of the motherboard using the tweezers. The wires aren't soldered on well.
Solder in the new speaker. Refer to the soldering guide if you're unsure on how to solder. To reassemble your device, follow these instructions in reverse order.
