Introduction
This guide will show you how to replace your broken screen.
Make sure to open the back cover easily using the plastic opening tool
  • Make sure to open the back cover easily using the plastic opening tool
Ajouter un commentaire
Remove back cover by prying away from the Kurio.
  • Remove back cover by prying away from the Kurio.
  • The easiest place to remove the cover is from the bottom and top; try to open it from right to left sides.
  • To remove the battery, make sure the four 5mm Philips screws on each side of your device is open using the Philips#1 Screwdriver.
  • After you remove your four 5mm Phillips screws, use your plastic opening tool to help you open the plastic cover of your device.
  • All these screws are identical so don't worry if you get them out of order.
  • Remove the plastic cover that is covering the camera area.
  • Separate the two halves of your Kurio Touch 4S and lay them besides each other.
  • Use Phillips # 1 screw to open the 4 screws on the motherboard.
  • Open the screws gently and do not apply too much force as you could damage the motherboard.
  • Use the plastic opener to remove the battery.
  • Use tweezers to remove the black tape that is attached to the motherboard.
  • Detach all the wire that are connected to the motherboard.
  • Also remove the camera module and other components that are attached to the motherboard.
  • For more information on soldering Click here
  • Remove the motherboard with the help of plastic opener.
  • Detach the power plug before you remove the motherboard.
  • Use the Plastic opener to remove the screen.
  • Do not apply too much pressure as the front cover could be damaged.
  • Use the soldering tool to remove the wire that is attached to the screen & the motherboard.
  • Use tweezers to remove the screen from your Kurio Toich 4S.
2 autre(s) ont terminé cette réparation.
Ali
Membre depuis le 21/01/2015
163 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 6-5, Brown Winter 2015 Membre de l'équipe USF Tampa, Team 6-5, Brown Winter 2015
USFT-BROWN-W15S6G5
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 7
Total : 1,141
