Aller au contenu principal
Kyocera DuraForce Pro Headphone Jack Replacement
Ce dont vous avez besoin
  1. Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: étape 1, image 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: étape 1, image 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement, Headphone Jack: étape 1, image 3 de 3
    • Flip the phone on its side so that the volume button is facing up.
    • Use the plastic opening tool to remove outer case of the phone.
    • Remove the 8 screws around the outer portion of the phone with a JIS #0 screwdriver.
  2. Kyocera DuraForce Pro Headphone Jack Replacement: étape 2, image 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 2, image 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 2, image 3 de 3
    • Remove the 2 screws with the same screwdriver bit.
    • Remove battery from the phone with plastic opening tool.
  3. Kyocera DuraForce Pro Headphone Jack Replacement: étape 3, image 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 3, image 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Once the battery pops out, use tweezers to gently pull the ribbon out along with it.
    • Remove the 2 screws along the sides of the mounting bracket, then remove the bracket.
  4. Kyocera DuraForce Pro Headphone Jack Replacement: étape 4, image 1 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 4, image 2 de 3 Kyocera DuraForce Pro Headphone Jack Replacement: étape 4, image 3 de 3
    • Remove final ribbon cable, lift the latch up, and then slide it down. The audio jack will then slide out.
Dylan Ulbricht
Membre depuis le 10/08/18
735 Réputation
5 tutoriels rédigés
Équipe
Sam Houston State, Team S15-G4, Blackburne Fall 2018 Membre de l'équipe Sam Houston State, Team S15-G4, Blackburne Fall 2018
SHSU-BLACKBURNE-F18S15G4
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 14
Total : 1,306
