Aller au contenu principal
Kyocera Echo Camera Replacement
Ce dont vous avez besoin
  1. Kyocera Echo Camera Replacement, Battery: étape 1, image 1 de 1
    • Orient the phone so that the screen is face down.
    • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
  2. Kyocera Echo Camera Replacement: étape 2, image 1 de 1
    • Pull up on the back cover and lift the top to separate it from the phone.
  3. Kyocera Echo Camera Replacement: étape 3, image 1 de 1
    • Pull the battery out of the device with a thin object such as your nail or credit card.
  4. Kyocera Echo Camera Replacement, Camera: étape 4, image 1 de 1
    • Unscrew four 4.3mm Phillips #000 screws.
  5. Kyocera Echo Camera Replacement: étape 5, image 1 de 1
    • Unscrew two 4.8mm Y000 screws.
  6. Kyocera Echo Camera Replacement: étape 6, image 1 de 2 Kyocera Echo Camera Replacement: étape 6, image 2 de 2
    • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
    • Do not apply too much pressure to the outer casing, as it could damage internal components.
  7. Kyocera Echo Camera Replacement: étape 7, image 1 de 2 Kyocera Echo Camera Replacement: étape 7, image 2 de 2
    • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
    • Be careful to not break the circuit board as it is connected to the hinge.
  8. Kyocera Echo Camera Replacement: étape 8, image 1 de 1
    • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
  9. Kyocera Echo Camera Replacement: étape 9, image 1 de 1
    • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
Alex Kinstedt
Membre depuis le 11/05/18
483 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S2-G6, Baechle Fall 2018 Membre de l'équipe IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 233
