Aller au contenu principal
Kyocera Hydro Life Charging Port Replacement
Ce dont vous avez besoin
  1. Kyocera Hydro Life Charging Port Replacement, Charging Port: étape 1, image 1 de 2 Kyocera Hydro Life Charging Port Replacement, Charging Port: étape 1, image 2 de 2
    • Remove the back of the phone.
  2. Kyocera Hydro Life Charging Port Replacement: étape 2, image 1 de 3 Kyocera Hydro Life Charging Port Replacement: étape 2, image 2 de 3 Kyocera Hydro Life Charging Port Replacement: étape 2, image 3 de 3
    • Remove the battery by pulling up on the end and towards yourself.
  3. Kyocera Hydro Life Charging Port Replacement: étape 3, image 1 de 1
    • Use a PH0 screwdriver to remove the 6 screws which are holding the panel in the phone.
  4. Kyocera Hydro Life Charging Port Replacement: étape 4, image 1 de 3 Kyocera Hydro Life Charging Port Replacement: étape 4, image 2 de 3 Kyocera Hydro Life Charging Port Replacement: étape 4, image 3 de 3
    • Remove the frame from around the back of the phone.
    • Then remove the back panel of the phone.
    • Remove the white sticker from in the middle of the phone.
  5. Kyocera Hydro Life Charging Port Replacement: étape 5, image 1 de 3 Kyocera Hydro Life Charging Port Replacement: étape 5, image 2 de 3 Kyocera Hydro Life Charging Port Replacement: étape 5, image 3 de 3
    • Desolder the 7 pins.
    • If you have never soldered before, follow this guide.
    • This type of soldering requires very specialized and expensive equipment. Please be careful if you decide to continue following this guide.
  6. Kyocera Hydro Life Charging Port Replacement: étape 6, image 1 de 2 Kyocera Hydro Life Charging Port Replacement: étape 6, image 2 de 2
    • Desolder the positive and negative terminals.
  7. Kyocera Hydro Life Charging Port Replacement: étape 7, image 1 de 1
    • Peel back the copper plated sticker.
    • If the copper plated sticker is broken, it must be replaced. If it is not broken during disassembly, it can be reused.
  8. Kyocera Hydro Life Charging Port Replacement: étape 8, image 1 de 1
    • Remove the motherboard without breaking it by placing it to the side. It will still be attached to the phone.
  9. Kyocera Hydro Life Charging Port Replacement: étape 9, image 1 de 1
    • Using force, remove the charging port from the charging slot.
  10. Kyocera Hydro Life Charging Port Replacement: étape 10, image 1 de 1
    • Replace the charging port and ribbon.
    • If the copper-plated sticker is damaged, it will need to be replaced as well.
Rebecca Lamb
Membre depuis le 09/21/18
327 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 9
Total : 990
