Aller au contenu principal
Introduction
This guide will show you how to replace the power button for a Kyocera Hydro Life phone.
  1. Remove the back cover.
    • Remove the back cover.
    • Pry the cover upward from the gap above the charger port as displayed.
  2. Remove the battery.
    • Remove the battery.
  3. Use a PH00 screwdriver to remove the 6 screws from the mid-frame. Removing the screws too carelessly can result in them being damaged or stripped.
    • Use a PH00 screwdriver to remove the 6 screws from the mid-frame.
    • Removing the screws too carelessly can result in them being damaged or stripped.
  4. Remove the back panel trim.
    • Remove the back panel trim.
    • The back panel trim is fairly thin, be cautious when removing it.
  5. Remove the back panel.
    • Remove the back panel.
    • Pry off the 4 corners first.
  6. Remove the power button with the tweezers. Remove the power button with the tweezers.
    • Remove the power button with the tweezers.
Haley Brown
Membre depuis le 21/09/2018
183 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 119
