Aller au contenu principal
Kyocera Hydro Life Rear-Facing Camera Replacement
Ce dont vous avez besoin
  1. Kyocera Hydro Life Rear-Facing Camera Replacement, Rear-Facing Camera: étape 1, image 1 de 1
    • Flip the phone so that the screen is facing down.
    • Gently remove the back cover with the grip at the bottom of the phone.
  2. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 2, image 1 de 3 Kyocera Hydro Life Rear-Facing Camera Replacement: étape 2, image 2 de 3 Kyocera Hydro Life Rear-Facing Camera Replacement: étape 2, image 3 de 3
    • Use the tab marked "PULL" to remove the battery from its enclosure.
  3. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 3, image 1 de 2 Kyocera Hydro Life Rear-Facing Camera Replacement: étape 3, image 2 de 2
    • Remove the six Phillips #00 screws from the back of the enclosure.
    • Use a plastic opening tool to gently remove the plastic piece surrounding the back of the phone enclosure.
  4. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 4, image 1 de 1
    • Remove the white sticker.
  5. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 5, image 1 de 2 Kyocera Hydro Life Rear-Facing Camera Replacement: étape 5, image 2 de 2
    • Using a pair of pliers, gently pry open the camera ribbon slot.
    • This will not take much pressure to open.
  6. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 6, image 1 de 1
    • Gently remove the camera ribbon.
    • Be very careful not to rip the ribbon. Use tweezers if needed.
  7. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 7, image 1 de 2 Kyocera Hydro Life Rear-Facing Camera Replacement: étape 7, image 2 de 2
    • Using a plastic prying tool, gently loosen all 4 corners of the motherboard.
    • Lift the motherboard away from the phone enclosure.
  8. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 8, image 1 de 1
    • Remove the black sticker.
    • Be careful when removing the sticker. The sticker will need to be replaced after replacing the camera.
  9. Kyocera Hydro Life Rear-Facing Camera Replacement: étape 9, image 1 de 1
    • Remove the camera from the motherboard.
    • This step requires breaking metal.
    • Only cut along the camera square.
Morgan Marshall
Membre depuis le 09/21/18
277 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 194
