Aller au contenu principal
Kyocera Hydro Vibe Camera Button Replacement
Ce dont vous avez besoin
  1. Kyocera Hydro Vibe Camera Button Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Camera Button Replacement: étape 2, image 1 de 3 Kyocera Hydro Vibe Camera Button Replacement: étape 2, image 2 de 3 Kyocera Hydro Vibe Camera Button Replacement: étape 2, image 3 de 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Camera Button Replacement, Trim: étape 3, image 1 de 1
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Camera Button Replacement: étape 4, image 1 de 2 Kyocera Hydro Vibe Camera Button Replacement: étape 4, image 2 de 2
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Camera Button Replacement: étape 5, image 1 de 1
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Camera Button Replacement, Camera Button: étape 6, image 1 de 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: étape 6, image 2 de 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: étape 6, image 3 de 3
    • Now that you have taken apart the trim, the camera button should be easily removable.
    • Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
    • Take the camera button out with tweezers.
Kunal Patel
Membre depuis le 01/29/16
562 Réputation
3 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 252
