Aller au contenu principal
Kyocera Hydro Vibe Internal Speaker Replacement
Ce dont vous avez besoin
  1. Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: étape 1, image 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: étape 1, image 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement, Internal Speaker: étape 1, image 3 de 3
    • Remove the back plate of the device by popping it off with your fingernail or a spudger.
  2. Kyocera Hydro Vibe Internal Speaker Replacement: étape 2, image 1 de 2 Kyocera Hydro Vibe Internal Speaker Replacement: étape 2, image 2 de 2
    • Remove six Phillips screws (screw length of 5.35 mm and screw head diameter of 2.95mm) on the back of the device using a Phillips #000 screwdriver.
  3. Kyocera Hydro Vibe Internal Speaker Replacement: étape 3, image 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 3, image 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 3, image 3 de 3
    • Remove the trim around the outside of the device by peeling it off with your hands.
  4. Kyocera Hydro Vibe Internal Speaker Replacement: étape 4, image 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 4, image 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 4, image 3 de 3
    • Remove battery using the spudger or your fingernails to pry the battery up out of the case.
  5. Kyocera Hydro Vibe Internal Speaker Replacement: étape 5, image 1 de 2 Kyocera Hydro Vibe Internal Speaker Replacement: étape 5, image 2 de 2
    • Now remove the rear frame, exposing the speaker. To remove the frame you can use the Spudger tool from the iFixit Tool kit or your hands.
  6. Kyocera Hydro Vibe Internal Speaker Replacement: étape 6, image 1 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 6, image 2 de 3 Kyocera Hydro Vibe Internal Speaker Replacement: étape 6, image 3 de 3
    • Remove the speaker from its location on the back frame using a spudger.
Ben Lange
Membre depuis le 11/01/18
139 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S3-G6, Harley Fall 2018 Membre de l'équipe IUPUI, Team S3-G6, Harley Fall 2018
IUPUI-HARLEY-F18S3G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 181
