Introduction
Sometimes the lock button gets stuck and needs to be replaced this guide will show you how to replace/ fix it.
Ce dont vous avez besoin
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
Once you have taken the trim apart, the lock button will be easily removable.
The lock button is located on the top of the phone.
Take the tweezers and remove the lock button.
