Introduction
If the trim becomes damaged, it may require replacement or repair. This guide will show you how to replace or repair the trim on your device.
Ce dont vous avez besoin
Look for a small indentation on the bottom of the phone.
Insert the plastic opening tool into the indentation and lift off the back casing.
Locate the screws holding the trim which are the four side screws on each corner.
Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
