Aller au contenu principal
Kyocera Hydro Vibe Volume Button Replacement
Ce dont vous avez besoin
  1. Kyocera Hydro Vibe Volume Button Replacement, Battery: étape 1, image 1 de 1
    • Make sure that the device is turned off before beginning.
    • Look for a small indentation on the bottom of the phone.
    • Insert the plastic opening tool into the indentation and lift off the back casing.
  2. Kyocera Hydro Vibe Volume Button Replacement: étape 2, image 1 de 3 Kyocera Hydro Vibe Volume Button Replacement: étape 2, image 2 de 3 Kyocera Hydro Vibe Volume Button Replacement: étape 2, image 3 de 3
    • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
    • Place the plastic opening tool in the indentation and lift the battery out of the socket.
  3. Kyocera Hydro Vibe Volume Button Replacement, Trim: étape 3, image 1 de 1
    • Locate the screws holding the trim which are the four side screws on each corner.
    • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
  4. Kyocera Hydro Vibe Volume Button Replacement: étape 4, image 1 de 2 Kyocera Hydro Vibe Volume Button Replacement: étape 4, image 2 de 2
    • Locate the clasps holding the trim in place.
    • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
  5. Kyocera Hydro Vibe Volume Button Replacement: étape 5, image 1 de 1
    • The trim is flimsy.
    • This is what the trim will look like once removed.
  6. Kyocera Hydro Vibe Volume Button Replacement, Volume Button: étape 6, image 1 de 3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: étape 6, image 2 de 3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: étape 6, image 3 de 3
    • Once you have taken out the trim, the volume button will be easily removable.
    • Locate the volume button, if you are looking at the back of the phone (battery side) then it will be on the right side.
    • Take the tweezers and remove the button.
Juliane Vo
Membre depuis le 01/31/16
255 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 301
