Aller au contenu principal
Kyvol Cybovac L20 Motherboard Replacement
Ce dont vous avez besoin
  1. Kyvol Cybovac L20 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Begin with the device laying on a flat surface with the power button facing up.
  2. Kyvol Cybovac L20 Motherboard Replacement: étape 2, image 1 de 2 Kyvol Cybovac L20 Motherboard Replacement: étape 2, image 2 de 2
    • Remove both of the side brushes.
  3. Kyvol Cybovac L20 Motherboard Replacement: étape 3, image 1 de 1
    • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
    • Remove the battery panel.
  4. Kyvol Cybovac L20 Motherboard Replacement: étape 4, image 1 de 2 Kyvol Cybovac L20 Motherboard Replacement: étape 4, image 2 de 2
    • Slightly lift the battery out of the compartment.
    • Disconnect the battery connector.
    • Completely remove the battery.
  5. Kyvol Cybovac L20 Motherboard Replacement, Motherboard: étape 5, image 1 de 1
    • Use a Phillips #1 screwdriver to remove 8 screws from the device as shown.
  6. Kyvol Cybovac L20 Motherboard Replacement: étape 6, image 1 de 2 Kyvol Cybovac L20 Motherboard Replacement: étape 6, image 2 de 2
    • Lift base up and unplug any cable connected form the motherboard into the rest of the components.
  7. Kyvol Cybovac L20 Motherboard Replacement: étape 7, image 1 de 1
    • Use a Phillips #1 screwdriver to remove the 4 screws holding the motherboard in place.
    • Lift the motherboard up and out of the chassis.
ErickAmaya
Membre depuis le 09/12/23
97 Réputation
1 tutoriel rédigé
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 6
Total : 50
