Aller au contenu principal
LCD X2gen Display disassembly
Ce dont vous avez besoin
  1. LCD X2gen Display disassembly, Display: étape 1, image 1 de 1
    • X2gen 22 lcd Screen repair guide
  2. LCD X2gen Display disassembly: étape 2, image 1 de 1
    • Power board displaying the capacitors to be replaced
  3. LCD X2gen Display disassembly: étape 3, image 1 de 1
    • Display viewed laying face down on the working table (my dining table)
    • Remove the 6 screws. 4 on the corners and 2 middle bottom.
  4. LCD X2gen Display disassembly: étape 4, image 1 de 1
    • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
  5. LCD X2gen Display disassembly: étape 5, image 1 de 1
    • Top middle
  6. LCD X2gen Display disassembly: étape 6, image 1 de 1
    • Front bezel removed.
    • Observe: the control board, bottom right.
    • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
  7. LCD X2gen Display disassembly: étape 7, image 1 de 1
    • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
    • This pic shows the right side
  8. LCD X2gen Display disassembly: étape 8, image 1 de 1
    • This pic shows the left side
  9. LCD X2gen Display disassembly: étape 9, image 1 de 2 LCD X2gen Display disassembly: étape 9, image 2 de 2
    • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
    • Slide the monitor to the left about 3-4 inch. to have access to the connections.
  10. LCD X2gen Display disassembly: étape 10, image 1 de 1
    • Carefully, unplug both connectors
  11. LCD X2gen Display disassembly: étape 11, image 1 de 2 LCD X2gen Display disassembly: étape 11, image 2 de 2
    • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
  12. LCD X2gen Display disassembly: étape 12, image 1 de 1
    • Remove the data connector and ground.
    • Lift display. Is now completely free
2 autres ont terminé cette réparation.
Aleks
Membre depuis le 02/11/14
201 Réputation
1 tutoriel rédigé
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 9
30 derniers jours : 53
Total : 2,020
