Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This repair guide will instruct the user on the proper technique for removing and replacing a broken keypad for a LG 1010 Cell Phone.
  1. Turn off the cell phone and place face down on a flat surface.
    • Turn off the cell phone and place face down on a flat surface.
  2. While sliding the gray tab up, lift battery up and away from the cell phone. While sliding the gray tab up, lift battery up and away from the cell phone.
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. Remove battery and set aside. Remove battery and set aside. Remove battery and set aside.
    • Remove battery and set aside.
  4. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  5. While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
    • While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
  6. Pull the antenna housing (black tube) towards bottom of phone and remove. Pull the antenna housing (black tube) towards bottom of phone and remove.
    • Pull the antenna housing (black tube) towards bottom of phone and remove.
  7. Unscrew the four screws on the back case using a T6 Torx Screwdriver. Unscrew the four screws on the back case using a T6 Torx Screwdriver.
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  8. Pull the back cover straight off the phone using your thumb and forefinger. Pull the back cover straight off the phone using your thumb and forefinger.
    • Pull the back cover straight off the phone using your thumb and forefinger.
  9. Pry off circuit board with a flathead screwdriver.
    • Pry off circuit board with a flathead screwdriver.
  10. Pull out flexible keypad.
    • Pull out flexible keypad.
Install new keypad and reassemble following these instructions in reverse order.
2 autre(s) ont terminé cette réparation.
Nicholas Schmidt
Membre depuis le 09/10/2010
97 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-25, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 membres
14 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 793
