Aller au contenu principal
LG 1010 LCD Screen Replacement
Ce dont vous avez besoin
  1. LG 1010 LCD Screen Replacement, Battery: étape 1, image 1 de 1
    • Turn off the cell phone and place face down on a flat surface.
  2. LG 1010 LCD Screen Replacement: étape 2, image 1 de 2 LG 1010 LCD Screen Replacement: étape 2, image 2 de 2
    • While sliding the gray tab up, lift battery up and away from the cell phone.
  3. LG 1010 LCD Screen Replacement: étape 3, image 1 de 3 LG 1010 LCD Screen Replacement: étape 3, image 2 de 3 LG 1010 LCD Screen Replacement: étape 3, image 3 de 3
    • Remove battery and set aside.
  4. LG 1010 LCD Screen Replacement, Front  Cover: étape 4, image 1 de 2 LG 1010 LCD Screen Replacement, Front  Cover: étape 4, image 2 de 2
    • Use a Spudger to remove the two front plastic covers to reveal screws.
  5. LG 1010 LCD Screen Replacement: étape 5, image 1 de 1
    • Remove two screws using a Torx T6 screwdriver.
  6. LG 1010 LCD Screen Replacement: étape 6, image 1 de 2 LG 1010 LCD Screen Replacement: étape 6, image 2 de 2
    • Pry off the screen front cover with a small flathead screwdriver.
  7. LG 1010 LCD Screen Replacement: étape 7, image 1 de 1
    • Insert a small flathead screwdriver into the hinge and separate hinge connection.
  8. LG 1010 LCD Screen Replacement: étape 8, image 1 de 1
    • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
  9. LG 1010 LCD Screen Replacement: étape 9, image 1 de 1
    • Remove remaining portion of the front case from the flexible circuit board.
    • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
  10. LG 1010 LCD Screen Replacement, Back Cover: étape 10, image 1 de 2 LG 1010 LCD Screen Replacement, Back Cover: étape 10, image 2 de 2
    • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
  11. LG 1010 LCD Screen Replacement: étape 11, image 1 de 2 LG 1010 LCD Screen Replacement: étape 11, image 2 de 2
    • Pull the back cover straight off the phone using your thumb and forefinger.
  12. LG 1010 LCD Screen Replacement, Keypad: étape 12, image 1 de 1
    • Pry off circuit board with a flathead screwdriver.
  13. LG 1010 LCD Screen Replacement: étape 13, image 1 de 1
    • Pull out flexible keypad.
  14. LG 1010 LCD Screen Replacement, LCD Screen: étape 14, image 1 de 1
    • The phone should now look like the picture to the left.
  15. LG 1010 LCD Screen Replacement: étape 15, image 1 de 2 LG 1010 LCD Screen Replacement: étape 15, image 2 de 2
    • Locate and detach the ribbon cable from circuit board.
  16. LG 1010 LCD Screen Replacement: étape 16, image 1 de 2 LG 1010 LCD Screen Replacement: étape 16, image 2 de 2
    • Remove the LCD Screen from the phone case and replace with a new LCD screen.
2 autres ont terminé cette réparation.
Nicholas Schmidt
Membre depuis le 10/09/10
97 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 3-25, Regan Fall 2010 Membre de l'équipe Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 membres
14 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 961
