Aller au contenu principal
LG 440G Keypad Replacement
Ce dont vous avez besoin
  1. LG 440G Keypad Replacement, Turn off phone.: étape 1, image 1 de 1
    • Turn the device off.
    • To do so, press and hold the red button.
  2. LG 440G Keypad Replacement, Flip phone.: étape 2, image 1 de 1
    • Flip the phone over.
  3. LG 440G Keypad Replacement, Rear cover removal.: étape 3, image 1 de 1
    • Slide the rear cover downward
    • Lift it off to access the battery
  4. LG 440G Keypad Replacement, Removal of battery.: étape 4, image 1 de 1
    • Locate the small rounded recess to get access to the battery
    • Gently, lift the battery
  5. LG 440G Keypad Replacement, Unscrew six screws along edges of casing: étape 5, image 1 de 1
    • Use a Phillips #00 screw driver to remove six screws.
    • Save screws for reassembly.
  6. LG 440G Keypad Replacement, Lift casing cover: étape 6, image 1 de 2 LG 440G Keypad Replacement, Lift casing cover: étape 6, image 2 de 2
    • Run the plastic opening tool along the edge of the phone to release the casing cover.
    • Lift the casing cover.
  7. LG 440G Keypad Replacement, Remove rectangular piece (with orange tape attached): étape 7, image 1 de 2 LG 440G Keypad Replacement, Remove rectangular piece (with orange tape attached): étape 7, image 2 de 2
    • Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
  8. LG 440G Keypad Replacement, Dislodge logic board: étape 8, image 1 de 1
    • Dislodge the logic board using a plastic opening tool.
  9. LG 440G Keypad Replacement, Lift logic board out: étape 9, image 1 de 1
    • Remove the logic board by lifting up.
  10. LG 440G Keypad Replacement, Lift keypad out of casing: étape 10, image 1 de 1
    • Remove the keypad from the phone by pushing the keypad itself out from the front of the phone. Then, lift the keypad out of the casing to separate the keypad from the casing.
JP Belanger
Membre depuis le 02/17/15
225 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-1, Buehl Winter 2015 Membre de l'équipe Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 724
