Introduction
Replacing the cameras if either are broken or not functioning properly.
Ce dont vous avez besoin
Insert the spudger into the notch on the bottom left side of the phone.
Apply light pressure to remove the back cover.
Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
Use the spudger to remove the inner shell.
Flip the inner shell over to expose the clips holding the command button.
Use the spudger to disconnect the ZIF connector securing the front-facing camera.
