Aller au contenu principal
LG Aristo Screen Replacement
Ce dont vous avez besoin
  1. LG Aristo Screen Replacement, Screen: étape 1, image 1 de 1
    • Turn off the device and make sure you are working on a flat, lit surface.
  2. LG Aristo Screen Replacement: étape 2, image 1 de 2 LG Aristo Screen Replacement: étape 2, image 2 de 2
    • Use an iFixit opening tool to pry off the back case.
  3. LG Aristo Screen Replacement: étape 3, image 1 de 3 LG Aristo Screen Replacement: étape 3, image 2 de 3 LG Aristo Screen Replacement: étape 3, image 3 de 3
    • Remove the SD and SIM cards by sliding the cards out with your finger.
  4. LG Aristo Screen Replacement: étape 4, image 1 de 3 LG Aristo Screen Replacement: étape 4, image 2 de 3 LG Aristo Screen Replacement: étape 4, image 3 de 3
    • Remove the battery by prying it up with a fingernail or opening tool from the bottom edge.
  5. LG Aristo Screen Replacement: étape 5, image 1 de 2 LG Aristo Screen Replacement: étape 5, image 2 de 2
    • Remove the ten screws from the midframe with a Phillips #000 screwdriver.
  6. LG Aristo Screen Replacement: étape 6, image 1 de 2 LG Aristo Screen Replacement: étape 6, image 2 de 2
    • Pry up on the screen with a plastic opening tool.
    • Try to avoid using a metal spudger as shown in the images as it has the possibility to damage the screen.
  7. LG Aristo Screen Replacement: étape 7, image 1 de 2 LG Aristo Screen Replacement: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Detach the cables from the press fit connectors.
    • There are four connectors in total, they consist of two on the cameras, one on the ear jack, and the one attached to the motherboard.
    • You can lift them up with you finger or you can use tweezers (optional).
  8. LG Aristo Screen Replacement: étape 8, image 1 de 2 LG Aristo Screen Replacement: étape 8, image 2 de 2
    • Gently remove the motherboard.
  9. LG Aristo Screen Replacement: étape 9, image 1 de 1
    • Replace the screen.
To reassemble your device, follow these instructions in reverse order. I hope that these steps have helped you with your issue.
2 autres ont terminé cette réparation.
Geobanny Cardenas
Membre depuis le 08/26/19
184 Réputation
1 tutoriel rédigé
Équipe
Gateway, Team S1-G5, Saknee Fall 2019 Membre de l'équipe Gateway, Team S1-G5, Saknee Fall 2019
GCC-SAKNEE-F19S1G5
4 membres
1 tutoriel rédigé
Un commentaire
Do i need Loca Glue to replace the outer Glass?
chuck - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 18
Total : 1,338
