Aller au contenu principal
LG BP220 Motherboard Replacement
Ce dont vous avez besoin
  1. LG BP220 Motherboard Replacement, Motherboard: étape 1, image 1 de 2 LG BP220 Motherboard Replacement, Motherboard: étape 1, image 2 de 2
    • Ensure the device is unplugged to prevent shocks.
    • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
    • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
  2. LG BP220 Motherboard Replacement: étape 2, image 1 de 3 LG BP220 Motherboard Replacement: étape 2, image 2 de 3 LG BP220 Motherboard Replacement: étape 2, image 3 de 3
    • Unhinge the tabs that attach the front panel to the unit:
    • Two tabs on the disc drive
    • Two tabs on the left and right side of the player
    • Be careful when handling these tabs. They are very fragile and can be easily broken.
    • Three tabs on the underside of the player
    • Pull panel away from case.
    • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
  3. LG BP220 Motherboard Replacement: étape 3, image 1 de 1
    • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
  4. LG BP220 Motherboard Replacement: étape 4, image 1 de 2 LG BP220 Motherboard Replacement: étape 4, image 2 de 2
    • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
    • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
  5. LG BP220 Motherboard Replacement: étape 5, image 1 de 3 LG BP220 Motherboard Replacement: étape 5, image 2 de 3 LG BP220 Motherboard Replacement: étape 5, image 3 de 3
    • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
    • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
    • Remove the power cord from the panel by carefully sliding it upwards from its seating.
  6. LG BP220 Motherboard Replacement: étape 6, image 1 de 2 LG BP220 Motherboard Replacement: étape 6, image 2 de 2
    • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
    • One screw inbetween the audio/video jacks
    • One screw to the bottom right of the audio/video jacks
    • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
  7. LG BP220 Motherboard Replacement: étape 7, image 1 de 2 LG BP220 Motherboard Replacement: étape 7, image 2 de 2
    • Handle the motherboards with care. They are fragile.
    • Beware of the capacitors as they may shock you when touched.
    • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
    • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
    • Use both hands to carefully lift the motherboard unit away from the player.
5 autres ont terminé cette réparation.
Bart Quicho
Membre depuis le 01/13/15
463 Réputation
3 tutoriels rédigés
Équipe
UW Tacoma, Team 1-1, Rose Winter 2015 Membre de l'équipe UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 membres
3 tutoriels rédigés
Un commentaire
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 8
30 derniers jours : 18
Total : 4,530
