Introduction
Replacing the speaker requires soldering and extensive disassembly. Refer to iFixit's soldering guide if you have never used a soldering iron or if you need a refresher.
Outils
Pièces
Aucune pièce spécifiée.
On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
Gently pry the LCD ribbon from the left side of the front cover using the plastic opening tool.
Use a soldering iron to desolder the lead junctions. If you have never used a soldering iron or you need a refresher, check out iFixit's soldering guide.
Separate the speaker from the LCD screen.
2 autre(s) ont terminé cette réparation.
