Aller au contenu principal
LG CF360 Rear Speaker Replacement
Ce dont vous avez besoin
  1. LG CF360 Rear Speaker Replacement, Battery: étape 1, image 1 de 2 LG CF360 Rear Speaker Replacement, Battery: étape 1, image 2 de 2
    • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
  2. LG CF360 Rear Speaker Replacement: étape 2, image 1 de 1
    • Lift and remove the battery.
  3. LG CF360 Rear Speaker Replacement, Back Cover: étape 3, image 1 de 2 LG CF360 Rear Speaker Replacement, Back Cover: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Remove the two screw covers at the top of phone with tweezers.
  4. LG CF360 Rear Speaker Replacement: étape 4, image 1 de 1
    • Remove the six Phillips #000 (3mm) screws.
  5. LG CF360 Rear Speaker Replacement: étape 5, image 1 de 3 LG CF360 Rear Speaker Replacement: étape 5, image 2 de 3 LG CF360 Rear Speaker Replacement: étape 5, image 3 de 3
    • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
    • The plastic side buttons fall out when you take the back cover off.
    • The back cover is connected to the speaker by red and black wires.
  6. LG CF360 Rear Speaker Replacement: étape 6, image 1 de 1
    • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
    • Set the back cover with the speaker aside.
  7. LG CF360 Rear Speaker Replacement, Rear Speaker: étape 7, image 1 de 1
    • Use the plastic opening tool to pry the speaker cover off of the phone.
  8. LG CF360 Rear Speaker Replacement: étape 8, image 1 de 1
    • Use the plastic opening tool to pry the speaker out of the back cover.
Annie White
Membre depuis le 10/18/13
262 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 4-27, Amido Fall 2013 Membre de l'équipe Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 membres
19 tutoriels rédigés
Un commentaire
Where can I buy the replacement parts?
Sarah Birkett - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 27
Total : 274
