Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Use this guide to replace the keyboard of the LG CG225.
  1. Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
    • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
  2. Remove a single Phillips #00 screw from beneath the cover.
    • Remove a single Phillips #00 screw from beneath the cover.
  3. Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
    • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
  4. Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
    • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
  5. Using a small plastic opening tool, remove the motherboard.
    • Using a small plastic opening tool, remove the motherboard.
  6. Using your fingers, remove the plastic keyboard.
    • Using your fingers, remove the plastic keyboard.
    • Loose buttons will sometimes fall off of the keyboard when it is removed.
Mackenzie
Membre depuis le 13/02/2014
1 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-3, Meza Spring 2014 Membre de l'équipe Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
4 membres
4 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 242
