Aller au contenu principal
LG Chocolate Sliding Front Replacement
Ce dont vous avez besoin
  1. LG Chocolate Sliding Front Replacement, Battery: étape 1, image 1 de 2 LG Chocolate Sliding Front Replacement, Battery: étape 1, image 2 de 2
    • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
    • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
  2. LG Chocolate Sliding Front Replacement, Back Cover: étape 2, image 1 de 1
    • You will need to use a Phillips #00 screwdriver.
    • Remove the four screws located at the corners beneath the battery.
    • Detach the back case from the phone.
  3. LG Chocolate Sliding Front Replacement: étape 3, image 1 de 3 LG Chocolate Sliding Front Replacement: étape 3, image 2 de 3 LG Chocolate Sliding Front Replacement: étape 3, image 3 de 3
    • Take the case off by using a plastic opening tool.
    • Continue using the plastic opening tool around the sides of the device.
    • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
    • The back speaker will be connected to the motherboard.
    • This must be disconnected in order to remove the case
  4. LG Chocolate Sliding Front Replacement, Sliding Front: étape 4, image 1 de 1
    • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
  5. LG Chocolate Sliding Front Replacement: étape 5, image 1 de 2 LG Chocolate Sliding Front Replacement: étape 5, image 2 de 2
    • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
  6. LG Chocolate Sliding Front Replacement: étape 6, image 1 de 2 LG Chocolate Sliding Front Replacement: étape 6, image 2 de 2
    • Pry off the plastic tabs that cover two screws, as shown in the first picture.
    • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
  7. LG Chocolate Sliding Front Replacement: étape 7, image 1 de 1
    • Pry off the back cover from the front of the case using a plastic opening tool.
2 autres ont terminé cette réparation.
Maci Miri
Membre depuis le 01/18/13
39 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 19-46, Regan Winter 2013 Membre de l'équipe Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 membres
22 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 8
Total : 300
