Introduction
Installing the Number Keypad and the LCD Screen can be done at the same time. Note, however, that the Keypad and the hardware casing are connected and must be installed together.
Ce dont vous avez besoin
Place the phone so the screen side is facing down.
Locate the latch at the end of the phone, opposite of the camera.
Remove the 5 screw covers on the back of the phone using a Push Pin.
After removing the circuit board and key board, separate the top part with the screen from the bottom part by detaching the hinges.
The Number Keypad and its metal casing are attached to the clear plastic screen that the LCD Screen was in. Replace both the Keypad and the casing as a unit.
