Ce dont vous avez besoin
Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
Remove the remaining 6 screws securing the plastic frame to the back housing
Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
Continue working your way around the phone, prying carefully with your prying tool
When you work the frame free, set it aside
Insert a small flathead screwdriver or black plastic spudger between the front silver bezel and the black plastic mid-frame
Gently pry on the bezel to release the clips adhering the screen to the mid-frame
Work your way around the phone, still using the small flathead or spudger, until the screen is fully separated
Remove the screen, taking care not to tear the flex cable that is still threaded through the housing.
Gently pry the charging port assembly's ribbon cable starting at the top (marked in blue)
Slowly peel the ribbon cable downward until the charging port assembly is no longer adhered to the housing
Remove the assembly and set it aside
2 autres ont terminé cette réparation.
