Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Pièces
Aucune pièce spécifiée.
  1. With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. Take the spudger and slide it around the perimeter of the device. Pull gently on the edges to get the panel to pop up. If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. Remove the 4 1.5 mm screws holding the speakers in place. Remove the 4 1.5 mm screws holding the speakers in place.
    • Remove the 4 1.5 mm screws holding the speakers in place.
  4. Put the spudger underneath the gold cap of the  cable and lift to disconnect from device. This cable can be damaged easily. This cable can be damaged easily.
    • Put the spudger underneath the gold cap of the cable and lift to disconnect from device.
    • This cable can be damaged easily.
  5. Pull the cable back and out of the way of the speaker.
    • Pull the cable back and out of the way of the speaker.
  6. Place the spudger in between the speaker and the device to  pop the speaker out of place. Pull the speaker out of the device.
    • Place the spudger in between the speaker and the device to pop the speaker out of place.
    • Pull the speaker out of the device.
  7. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  8. Remove the two screws on the white panel on the bottom right side. Remove the two screws on the white panel on the bottom right side.
    • Remove the two screws on the white panel on the bottom right side.
  9. Remove the white panel. Remove the white panel.
    • Remove the white panel.
  10. Remove the vibrator from the underside of the white panel.
    • Remove the vibrator from the underside of the white panel.
  11. Remove the 3 silver 1.5 mm screws that remain. Remove the 3 silver 1.5 mm screws that remain.
    • Remove the 3 silver 1.5 mm screws that remain.
  12. Remove the 2 black 1.5 mm screws. Remove the 2 black 1.5 mm screws.
    • Remove the 2 black 1.5 mm screws.
  13. Insert metal spudger under the side of the gold strip and pull. Insert metal spudger under the side of the gold strip and pull.
    • Insert metal spudger under the side of the gold strip and pull.
  14. Place spudger under the top of the gold bar and gently pry up. Place spudger under the top of the gold bar and gently pry up.
    • Place spudger under the top of the gold bar and gently pry up.
  15. Pull on top of the silver block until gold bar lifts.
    • Pull on top of the silver block until gold bar lifts.
  16. Place spudger under the battery and run it around the edge to loosen it.
    • Place spudger under the battery and run it around the edge to loosen it.
  17. Pull the battery out.
    • Pull the battery out.
Charlie Castorena
Membre depuis le 18/09/2018
417 Réputation
3 tutoriels rédigés
Équipe
I have followed your guide (LG G Pad 8.3 4G Battery Replacement) but what see when I pry off the screen is not what is on your pic of step 2.
It appears that I have to pry off the back panel to actually see the battery, the speakers and the gold cable.
How can I pry off the back panel?
Thanks,
Ed
Ed Miller - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 6
Total : 268
