Introduction
This guide will walk you through with replacing the motherboard of you LG G Vista. You will need tweezers, a Phillips screwdriver #000, and a small plastic spudger, or your thumb nail.
Outils
Aucun outil requis.
Pièces
Aucune pièce nécessaire.
Make sure the device is powered off.
  • Make sure the device is powered off.
Ajouter un commentaire
Remove the back cover by gently prying open the case of the device from the charging port.
  • Remove the back cover by gently prying open the case of the device from the charging port.
Lift the battery out of its place by prying up from the small notch at the base of the battery.
  • Lift the battery out of its place by prying up from the small notch at the base of the battery.
Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
Remove the hard shell covering the motherboard.
  • Remove the hard shell covering the motherboard.
Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
Use the tweezers to remove the four connectors as well as the back camera. Be careful not to directly touch the camera lenses.
  • Use the tweezers to remove the four connectors as well as the back camera.
  • Be careful not to directly touch the camera lenses.
Lift up and remove the motherboard from the device.
  • Lift up and remove the motherboard from the device.
Key Baker
Membre depuis le 18/01/2018
676 Réputation
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 16
Total : 112
