Introduction
This guide will show you how to remove the battery housing for the LG G Watch R.
Ce dont vous avez besoin
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
Use a plastic opening tool to pry the battery out of the device.
Pry the battery housing from the top right corner using a spudger.
Once loosened, remove the battery housing.
2 autres ont terminé cette réparation.
1 commentaire de tutoriel
Hi there, do you know where can i buy the battery housing? Thank you..
