Introduction
In this guide, you'll disconnect all components in order to replace a faulty or damaged motherboard in your LG G Watch R. Motherboard failure will typically stop your watch from working or even turning on. However, the motherboard is usually the most expensive part of the device to replace—so check the troubleshooting page to rule out other factors before replacing the motherboard. Since your data is stored on a chip on the motherboard, be aware that replacing the board will cause you to lose any saved data.
Ce dont vous avez besoin
Place the watch upside down on a hard surface so that its back case is facing upright.
Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
3 autres ont terminé cette réparation.
3 commentaires
Where do I buy a replacement motherboard from??
Did you ever find anywhere to order a replacement motherboard?
