Aller au contenu principal
Ce dont vous avez besoin
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre LG G Watch R, utilisez notre manuel de réparation.
  1. LG G Watch R Teardown, Front and Back: étape 1, image 1 de 2 LG G Watch R Teardown, Front and Back: étape 1, image 2 de 2
    • LG G Watch R assembly.
  2. LG G Watch R Teardown, Removing the back cover: étape 2, image 1 de 2 LG G Watch R Teardown, Removing the back cover: étape 2, image 2 de 2
    • First remove the watch band using a small flat screw driver to compress the spring loaded pin.
    • Remove the four T4 torx screws (Green).
    • Carefully pry the base off using a thin flat screw driver
  3. LG G Watch R Teardown, Removing the Board: étape 3, image 1 de 2 LG G Watch R Teardown, Removing the Board: étape 3, image 2 de 2
    • Disconnect the four electrical connectors from the board
    • Orange - Battery connector
    • Blue - button and charging connector
    • Green - Backlight
    • Purple - O-LED Controller + Mic
    • Remove the three phillips screws securing the board down. Then lift the board off the base
  4. LG G Watch R Teardown, The Battery: étape 4, image 1 de 2 LG G Watch R Teardown, The Battery: étape 4, image 2 de 2
    • The battery is below the board.
    • The battery can easily be pried out using a small flat head screwdriver.
  5. LG G Watch R Teardown, Battery housing: étape 5, image 1 de 1
    • Using a small pliers and a small flat screwdriver the battery housing comes out easily.
  6. LG G Watch R Teardown, P-OLED Panel: étape 6, image 1 de 3 LG G Watch R Teardown, P-OLED Panel: étape 6, image 2 de 3 LG G Watch R Teardown, P-OLED Panel: étape 6, image 3 de 3
    • Pictures of the front and back of the 1.3" P-OLED.
    • The screen is glued in.
Dustin Richards
Membre depuis le 01/20/15
332 Réputation
1 tutoriel rédigé
8 commentaires
Is there a wifi antenna inside the LG G watch R?
Fernando Perez - Réponse
Yes, there is a WiFi antenna inside the LG G Watch R, however WiFi functionality was only recently added to the G Watch R in a more recent update via Android Wear.
Mark Fortune -
Are there differences between the UK as US G Watch R?
James Kemble - Réponse
Where could I find a battery for replacement?
Thanks in advance.
Fab - Réponse
Any tips for what to check if the touchscreen turns on but is non-responsive ?
richard - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 11
Total : 20,243
