Introduction
This guide will walk you through the process of how to replace the vibrator motor for the LG G2.
Ce dont vous avez besoin
Étape 1 Motherboard
Attention : les étapes 1 à 10 sont issues d'un tutoriel marqué comme en cours.
Using the plastic opening tool, or the thin side of the spudger to separate the back cover from the phone. Start at the bottom corner of the phone. Be gentle because it may cause cosmetic and internal damage if not done with care.
With the back cover removed you will get a view like this.
Use the Phillips 00 screw driver to remove all visible screws. Try to organize the screws so there is no confusion when reassembling the phone.
6 silver cross head phillips #1 4mm screws circled in red.
5 gold cross head phillips #1 4mm screws circled in yellow.
1 black cross head phillips #2 2mm screws circled in blue.
After all connector are loosened up the motherboard should be free, but before removing it lets disconnect it a little further.
The flex cables running on the left and right side of the battery are connected to a smaller board connected which on their turn is connected with small amounts of adhesive materials to the motherboard. Use the spudger to carefully separate the smaller board of the motherboard.
This is a picture of the location of the vibrator motor.
It may require some prying due to the cohesive material used to hold it down so be gentle when removing.
Make use of spudger.
4 autres ont terminé cette réparation.
