Aller au contenu principal
LG G5 Rear Camera Replacement
Ce dont vous avez besoin
  1. LG G5 Rear Camera Replacement, Front Panel Assembly: étape 1, image 1 de 2 LG G5 Rear Camera Replacement, Front Panel Assembly: étape 1, image 2 de 2
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Rear Camera Replacement: étape 2, image 1 de 3 LG G5 Rear Camera Replacement: étape 2, image 2 de 3 LG G5 Rear Camera Replacement: étape 2, image 3 de 3
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
  3. LG G5 Rear Camera Replacement: étape 3, image 1 de 2 LG G5 Rear Camera Replacement: étape 3, image 2 de 2
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
  4. LG G5 Rear Camera Replacement: étape 4, image 1 de 1
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    Holy this step is hard
    Nickstar - Réponse
    It is, i can’t seem to do it too easily either. Maybe i need to heat it up? I don’t want to damage it as it will still be used as a camera.
    Theawesomegamer2yt Gaming -
  5. LG G5 Rear Camera Replacement: étape 5, image 1 de 2 LG G5 Rear Camera Replacement: étape 5, image 2 de 2
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    My LCD started to let loose using this way to saparate the top and bottom of the phone.
    I used a guitar pick and slided it from the bottom to the top like the dude in this video: https://www.youtube.com/watch?v=XV10zyw8...
    Didn’t had to use a lot of force this way, and my screen almost didn’t bend !
    Ray Bas - Réponse
    Yep! I did it also with this method. Wayy better and easier ;)
    ronlad.garud -
    My screen cracked taking it out following ifixit method . Right when I got to the part where it starts to curve at the top. Just shattered.
    Randy - Réponse
    I found it easier to run the tool or a pick along the sides, and then sort of hinge the thing open at the top rather than running completely around the screen. It gets a little dicey where the glass starts to curve.
    Arthur Heller - Réponse
  6. LG G5 Rear Camera Replacement: étape 6, image 1 de 2 LG G5 Rear Camera Replacement: étape 6, image 2 de 2
    • Peel the screen away from the body. The two parts should be completely separated.
  7. LG G5 Rear Camera Replacement, Rear Camera: étape 7, image 1 de 3 LG G5 Rear Camera Replacement, Rear Camera: étape 7, image 2 de 3 LG G5 Rear Camera Replacement, Rear Camera: étape 7, image 3 de 3
    • Insert the plastic opening tool between the camera-ribbon connector and the motherboard, then pull up. It should pop out easily.
  8. LG G5 Rear Camera Replacement: étape 8, image 1 de 2 LG G5 Rear Camera Replacement: étape 8, image 2 de 2
    • After detaching the ribbon, carefully remove the camera using tweezers
    The camera is attached to the frame with adhesive- use a nylon screen opening tool or a spludger to help lift the camera off of the body. Tilt it out at a 45 degree angle to clear the PCB and you're ready for replacement!
    Camden Stensland - Réponse
    I found it easier to use some guitar picks to separate the screen from the body. I lifted the screen away from the body using a prying tool, then insert the guitar pick in the gap. I worked it along the seam until I got to the top of the phone, then worked on the other side.
    James Arthurs - Réponse
34 autres ont terminé cette réparation.
Parker Reynolds
Membre depuis le 10/03/16
932 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 18-2, Forte Fall 2016 Membre de l'équipe Cal Poly, Team 18-2, Forte Fall 2016
CPSU-FORTE-F16S18G2
4 membres
15 tutoriels rédigés
6 commentaires
This worked great and took me about 10 minutes!
Mark - Réponse
Great instructions. This was my first time taking apart any phone. Everything went smoothly and my camera now works! thank you
Christopher Piatt - Réponse
the camera is held down with sticky tape and I wasn’t comfortable pulling hard under the processing board, so I pulled the six screws holding that down and removed it first. Unfortunately for me the new camera still doesn’t focus…
Ray White - Réponse
This worked great for me. I was a little nervous prying on my phone, especially when I heard the first POP. But after that, it was not hard at all. The new camera focuses great for me now and I can get back to taking great pictures with my G5!
Thanks for the detailed instructions, tools and affordable part!
Brad - Réponse
You may want to mention that the original camera is glued in. It takes a bit of prying to pop it out.
Ryan - Réponse
I can’t pry the screen off with the plastic tools I purchased with ifixit. what now?
Suzanne Artzberger - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 17,178
