Aller au contenu principal
Pour réparer ensemble - Je crée un compte
LG G6 Motherboard Replacement
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. LG G6 Motherboard Replacement, iOpener Heating: étape 1, image 1 de 2 LG G6 Motherboard Replacement, iOpener Heating: étape 1, image 2 de 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    Demander à FixBot
  2. LG G6 Motherboard Replacement: étape 2, image 1 de 1
    • Heat the iOpener for thirty seconds.
    • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
    Demander à FixBot
  3. LG G6 Motherboard Replacement: étape 3, image 1 de 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
    Demander à FixBot
  4. LG G6 Motherboard Replacement, Alternate iOpener heating method: étape 4, image 1 de 2 LG G6 Motherboard Replacement, Alternate iOpener heating method: étape 4, image 2 de 2
    • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
    • Fill a pot or pan with enough water to fully submerge an iOpener.
    • Heat the water to a boil. Turn off the heat.
    • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
    • Use tongs to extract the heated iOpener from the hot water.
    • Thoroughly dry the iOpener with a towel.
    • The iOpener will be very hot, so be careful to hold it only by the end tabs.
    • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
    Demander à FixBot
  5. LG G6 Motherboard Replacement, Battery: étape 5, image 1 de 1
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
    Demander à FixBot
  6. LG G6 Motherboard Replacement: étape 6, image 1 de 3 LG G6 Motherboard Replacement: étape 6, image 2 de 3 LG G6 Motherboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Plastic Cards
    $2.99
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    Demander à FixBot
  7. LG G6 Motherboard Replacement: étape 7, image 1 de 2 LG G6 Motherboard Replacement: étape 7, image 2 de 2
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    Demander à FixBot
  8. LG G6 Motherboard Replacement: étape 8, image 1 de 2 LG G6 Motherboard Replacement: étape 8, image 2 de 2
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
    Demander à FixBot
  9. LG G6 Motherboard Replacement: étape 9, image 1 de 1
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
    Demander à FixBot
  10. LG G6 Motherboard Replacement: étape 10, image 1 de 3 LG G6 Motherboard Replacement: étape 10, image 2 de 3 LG G6 Motherboard Replacement: étape 10, image 3 de 3
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
    Demander à FixBot
  11. LG G6 Motherboard Replacement, Motherboard: étape 11, image 1 de 2 LG G6 Motherboard Replacement, Motherboard: étape 11, image 2 de 2
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
    Demander à FixBot
  12. LG G6 Motherboard Replacement: étape 12, image 1 de 3 LG G6 Motherboard Replacement: étape 12, image 2 de 3 LG G6 Motherboard Replacement: étape 12, image 3 de 3
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
    Demander à FixBot
  13. LG G6 Motherboard Replacement: étape 13, image 1 de 2 LG G6 Motherboard Replacement: étape 13, image 2 de 2
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
    Demander à FixBot
4 autres ont terminé cette réparation.
David Pugliese
Membre depuis le 09/26/17
1 156 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 membres
11 tutoriels rédigés
4 commentaires de tutoriel
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - Réponse Partager
i found one on ebay
Greg - Réponse Partager
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - Réponse Partager
very good detail
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 61
Total : 8,000
