Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to replace the motherboard on your LG G6.
  1. We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener. Place the iOpener in the center of the microwave.
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
  2. Heat the iOpener for thirty seconds.
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
  3. Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  4. Apply the heated iOpener to the  edge of the phone for about 2 minutes.
    • Apply the heated iOpener to the edge of the phone for about 2 minutes.
  5. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  6. When the back panel is heated, apply the suction cup close to a corner of the phone.  Lift up and insert a halberd spudger or opening pick under the rear glass. Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive. Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
    • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
    • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
    • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
  7. Using a Philips 000 bit, remove 11 screws from the highlighted locations. Using a Philips 000 bit, remove 11 screws from the highlighted locations.
    • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
  8. With the screws removed, remove the lower frame components, followed by the upper mid-frame.  Both components can be removed with a little prying. With the screws removed, remove the lower frame components, followed by the upper mid-frame.  Both components can be removed with a little prying.
    • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
  9. Begin battery removal by very gently prying off the power ribbon with a  plastic card or a nylon spudger.
    • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
  10. Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive. Do not use a knife as you may pierce the battery. Do not use a knife as you may pierce the battery.
    • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
    • Do not use a knife as you may pierce the battery.
  11. Locate the sim card tray release mechanism on the right edge. Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
    • Locate the sim card tray release mechanism on the right edge.
    • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
  12. Gently pry off the two connectors at the bottom of the phone. Pry off the tape covering the vibrator. Pry off the tape covering the vibrator.
    • Gently pry off the two connectors at the bottom of the phone.
    • Pry off the tape covering the vibrator.
  13. The motherboard is now removable by gently lifting. Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
    • The motherboard is now removable by gently lifting.
    • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
3 autre(s) ont terminé cette réparation.
David Pugliese
Membre depuis le 26/09/2017
1 096 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Passmore Fall 2017 Membre de l'équipe USF Tampa, Team S2-G6, Passmore Fall 2017
USFT-PASSMORE-F17S2G6
4 membres
11 tutoriels rédigés
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - Réponse
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 26
Total : 6,022
