Aller au contenu principal
LG Intuition Camera Replacement
Ce dont vous avez besoin
  1. LG Intuition Camera Replacement, Battery: étape 1, image 1 de 1
    • Turn the device so the two bottom screws are shown.
  2. LG Intuition Camera Replacement: étape 2, image 1 de 1
    • Remove the two 7mm screws holding the back panel of the phone using the P5 bit and magnetic driver.
  3. LG Intuition Camera Replacement: étape 3, image 1 de 1
    • Carefully use the plastic opening tool to pry the back panel of the phone from the front screen. This will expose the battery and other parts.
  4. LG Intuition Camera Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the 5mm screw holding the metal bracket that protects the battery's ribbon cable.
  5. LG Intuition Camera Replacement: étape 5, image 1 de 1
    • Carefully use the plastic opening tool to pry the ribbon cable connecting the battery to the motherboard of the phone.
  6. LG Intuition Camera Replacement: étape 6, image 1 de 2 LG Intuition Camera Replacement: étape 6, image 2 de 2
    • Gently raise the battery from its compartment.
  7. LG Intuition Camera Replacement, Plastic Motherboard Shield: étape 7, image 1 de 1
    • Remove the thirteen 5mm screws holding the plastic shield covering the motherboard using the Phillips #00 screwdriver.
  8. LG Intuition Camera Replacement: étape 8, image 1 de 1
    • Carefully use the plastic opening tool to pry the plastic shield from the motherboard. This will expose the motherboard and ribbon cables for each component.
  9. LG Intuition Camera Replacement, Camera: étape 9, image 1 de 1
    • Carefully use the plastic opening tool to pry the ribbon cable below the camera itself from the motherboard.
  10. LG Intuition Camera Replacement: étape 10, image 1 de 1
    • Using the ribbon beneath the camera lift it upwards and pull the camera out.
Thomas Morrissey
Membre depuis le 10/25/18
616 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team S3-G4, Peak Fall 2018 Membre de l'équipe UMass Dartmouth, Team S3-G4, Peak Fall 2018
UMASSD-PEAK-F18S3G4
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 104
