Aller au contenu principal
LG K40 Battery Replacement
  1. LG K40 Battery Replacement, Separating the back: étape 1, image 1 de 2 LG K40 Battery Replacement, Separating the back: étape 1, image 2 de 2
    • Use an opening pick to separate the back panel from the phone.
  2. LG K40 Battery Replacement: étape 2, image 1 de 2 LG K40 Battery Replacement: étape 2, image 2 de 2
    • Pull the back panel away.
  3. LG K40 Battery Replacement: étape 3, image 1 de 2 LG K40 Battery Replacement: étape 3, image 2 de 2
    • Watch out, there is a touch sensor cable still attached to the main board.
  4. LG K40 Battery Replacement, Unscrew: étape 4, image 1 de 1
    • Unscrew all screws pictured.
  5. LG K40 Battery Replacement, Remove plastic cover: étape 5, image 1 de 3 LG K40 Battery Replacement, Remove plastic cover: étape 5, image 2 de 3 LG K40 Battery Replacement, Remove plastic cover: étape 5, image 3 de 3
    • Remove the black plastic as pictured.
  6. LG K40 Battery Replacement, Disconnect battery: étape 6, image 1 de 1
    • Disconnect the battery.
  7. LG K40 Battery Replacement, Remove battery: étape 7, image 1 de 3 LG K40 Battery Replacement, Remove battery: étape 7, image 2 de 3 LG K40 Battery Replacement, Remove battery: étape 7, image 3 de 3
    • Caution: Don't jab the battery with any sharp tools. A punctured battery may leak dangerous chemicals or catch fire.
    • Pry up the battery. This will require a lot of force, but fortunately, there aren’t any cables under it.
    • Look at that carnage…
    • You can use adhesive softener to make the job of removing the battery easier.
guardian10
Membre depuis le 03/10/22
10 292 Réputation
15 tutoriels rédigés
Équipe
Android Alliance Membre de l'équipe Android Alliance
Community
92 membres
734 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 20
Total : 925
