Introduction
This guide will help you remove the external housing and replace it.
Ce dont vous avez besoin
Carefully slide the spudger behind the main ribbon in order to separate it from the inside cover of the phone.
Poke out rubber covers using a spudger or pointy object, such as a thumb tack.
The back of the keypad is shown here, next to the logic board (the logic board is turned over to expose the buttons).
Wedge a spudger or another harder prying tool in the connection between the top cover and the bottom cover on the right side.
Use a large amount of force to push the top cover off the bottom cover's blue extrusion.
When separating the top cover from the bottom cover, be careful not to tear the ribbon as you pull it out from the hinge.
