Aller au contenu principal
LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement
Ce dont vous avez besoin
  1. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: étape 1, image 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: étape 1, image 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement, Filter: étape 1, image 3 de 3
    • Find a replacement water filter based on the model number for your fridge.
    • You can also bring your old water filter to a store to get a suitable replacement that way.
  2. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 2, image 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 2, image 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 2, image 3 de 3
    • For the best result, it's best to buy the original filter that was made for the fridge as opposed to an aftermarket water filter.
    • Remove the water filter from the box .
    • Remove the cap from the water filter.
  3. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 3, image 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 3, image 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 3, image 3 de 3
    • Open the water filter bay in the top left corner of the fridge.
    • Remove the existing water filter inside. Or, if your fridge doesn't yet have a water filter, remove the green cap instead.
  4. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 4, image 1 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 4, image 2 de 3 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 4, image 3 de 3
    • Angle the receiver in the fridge downward so that the filter is easy to plug in.
    • Firmly press the water filter into the receiver until it is snug and attached.
    • If the water filter falls out once you let go, you simply need to press harder into the receiver.
  5. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 5, image 1 de 2 LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 5, image 2 de 2
    • Shut the water filter cover.
  6. LG LMWS27626S French 4 Door Refrigerator Water Filter Replacement: étape 6, image 1 de 1
    • Purge the system by dispensing water for about 2-3 minutes, or until you have cycled through approximately 64 ounces.
    • Your water should now be clean and crystal clear!
Ligne d'arrivée
Luc Charles
Membre depuis le 03/22/21
154 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team S3-G4, Saloman Spring 2021 Membre de l'équipe UMass Dartmouth, Team S3-G4, Saloman Spring 2021
UMASSD-SALOMAN-S21S3G4
1 membre
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 19
30 derniers jours : 103
Total : 6,656
