Aller au contenu principal
Introduction
How to Remove the Battery
  1. First locate the button and the bottom of the cover where the arrow is. Press down on the button. While pushing down on the button, slide the cover up towards the hinge until the cover comes off. The battery will be visible after removing the back cover.
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. Simultaneously push the battery forward and pull up from the bottom. Simultaneously push the battery forward and pull up from the bottom.
    • Simultaneously push the battery forward and pull up from the bottom.
  3. Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
Andrea
Membre depuis le 19/04/2010
110 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 10-44, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,370
