Aller au contenu principal
LG LX150 Motherboard Replacement
Ce dont vous avez besoin
  1. LG LX150 Motherboard Replacement, Back Cover: étape 1, image 1 de 3 LG LX150 Motherboard Replacement, Back Cover: étape 1, image 2 de 3 LG LX150 Motherboard Replacement, Back Cover: étape 1, image 3 de 3
    • First locate the button and the bottom of the cover where the arrow is. Press down on the button.
    • While pushing down on the button, slide the cover up towards the hinge until the cover comes off.
    • The battery will be visible after removing the back cover.
  2. LG LX150 Motherboard Replacement, Battery: étape 2, image 1 de 2 LG LX150 Motherboard Replacement, Battery: étape 2, image 2 de 2
    • Simultaneously push the battery forward and pull up from the bottom.
  3. LG LX150 Motherboard Replacement: étape 3, image 1 de 1
    • Once the battery is loose it can be easily removed. The phone's ID tag will be visible once the battery is removed.
    • Be careful of damaged or leaking batteries. If your battery appears damaged, remove it with care and find a replacement.
  4. LG LX150 Motherboard Replacement, Internal Back Cover: étape 4, image 1 de 3 LG LX150 Motherboard Replacement, Internal Back Cover: étape 4, image 2 de 3 LG LX150 Motherboard Replacement, Internal Back Cover: étape 4, image 3 de 3
    • Remove the 7 phillips screws indicated by the red arrows using the phillips #0 screwdriver.
    • Insert the flat end of the spudger in-between the black and blue phone casing on the side of the phone and split the the blue and black apart. Work your way around the perimeter of the cover, loosening all corners.
  5. LG LX150 Motherboard Replacement: étape 5, image 1 de 2 LG LX150 Motherboard Replacement: étape 5, image 2 de 2
    • Remove the internal back cover after loosening all the corners.
    • The second picture below is what you will see after removing the internal back cover.
  6. LG LX150 Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Lift the motherboard from the bottom to loosen it.
  7. LG LX150 Motherboard Replacement: étape 7, image 1 de 1
    • Remove the pin socket that connects the screen to the motherboard by pulling up away from the motherboard.
  8. LG LX150 Motherboard Replacement: étape 8, image 1 de 2 LG LX150 Motherboard Replacement: étape 8, image 2 de 2
    • Remove the motherboard.
    • The keypad will now be visible, as shown in the second picture.
Daniel Simpson
Membre depuis le 04/18/10
60 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 10-44, Garner Spring 2010 Membre de l'équipe Cal Poly, Team 10-44, Garner Spring 2010
CPSU-GARNER-S10S10G44
4 membres
18 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 11
Total : 1,485
