Introduction
This guide will walk you through the process of replacing a earpiece speaker.
Pièces
Aucune pièce nécessaire.
Flip phone to the back so you can access back of the phone which holds the battery.
  • Flip phone to the back so you can access back of the phone which holds the battery.
Ajouter un commentaire
Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
  • Pry the back of the phone open in the incision area at the bottom of the phone with your opening tool in an upward direction to retrieve access to the battery.
  • Once the back is removed you will have access to the 8 screws that need to be unscrewed with the Phillips #0 screwdriver. Once all screws are free use the opening tool to pry the back frame of the phone apart.
  • At this point you should have access to the motherboard.
  • Use opening tool to get the earpiece.
Geul Kim
Membre depuis le 29/01/2018
505 Réputation
5 tutoriels rédigés
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 104
