Aller au contenu principal
Introduction
Make sure your device is turned off before beginning this process.
  1. Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage. Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
    • Pry the back cover off of the phone with your fingernail. There is a notch located at the bottom of the phone for improved leverage.
  2. The battery is the large black rectangle towards the bottom half of the phone. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out. There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
    • The battery is the large black rectangle towards the bottom half of the phone.
    • There is a semi-circular notch at the bottom edge of the battery. Press against and up on the battery to pop it out.
2 autre(s) ont terminé cette réparation.
Dale Pearson
Membre depuis le 22/09/2014
784 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 10-6, Brown Fall 2014 Membre de l'équipe USF Tampa, Team 10-6, Brown Fall 2014
USFT-BROWN-F14S10G6
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 544
