Aller au contenu principal
LG Optimus Fuel Speaker Replacement
Ce dont vous avez besoin
  1. LG Optimus Fuel Speaker Replacement, Battery: étape 1, image 1 de 2 LG Optimus Fuel Speaker Replacement, Battery: étape 1, image 2 de 2
    • Use the opening on the right side of the phone to pull off the plastic back cover.
  2. LG Optimus Fuel Speaker Replacement: étape 2, image 1 de 3 LG Optimus Fuel Speaker Replacement: étape 2, image 2 de 3 LG Optimus Fuel Speaker Replacement: étape 2, image 3 de 3
    • Use the curved opening at the center-bottom of the battery to carefully remove the old battery.
  3. LG Optimus Fuel Speaker Replacement, Speaker: étape 3, image 1 de 3 LG Optimus Fuel Speaker Replacement, Speaker: étape 3, image 2 de 3 LG Optimus Fuel Speaker Replacement, Speaker: étape 3, image 3 de 3
    • Remove the six 1.4mm screws using a Phillips head screwdriver with a size PH00 bit. Then fully remove the back panel with a plastic opening tool.
  4. LG Optimus Fuel Speaker Replacement: étape 4, image 1 de 3 LG Optimus Fuel Speaker Replacement: étape 4, image 2 de 3 LG Optimus Fuel Speaker Replacement: étape 4, image 3 de 3
    • Remove the speaker from the back panel. You may have to use some tweezers if you are having a hard time grabbing the speaker with your fingers.
    • Remember to take note of where the two springs on the speaker are positioned before removing it. Install the new speaker with the springs in this same position.
Jason Owen
Membre depuis le 02/01/16
572 Réputation
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 238
