Introduction
This guide explain step by step how to replace the battery of your LG Optimus G with a couple of tools.
SIM eject tool
  • SIM eject tool
Ajouter un commentaire
Remove the 2 screws holding the back cover using a T5 screwdriver.
  • Remove the 2 screws holding the back cover using a T5 screwdriver.
  • Use a guitar pick or a plastic opening tool to free the clips on the top and each side of the back cover.
  • Use an opening pick to pry off the rear case.
  • Remove the tape over the battery, the screws and the antenna connector cord.
  • Be careful removing the golden tape because it is below the antenna connector cord.
  • Remove the the screws securing the battery cable connector.
  • Disconnect the battery cable.
  • The battery is held down by some adhesive.
  • Carefully heat the battery to loosen the adhesive holding it to the case.
  • Pry the battery up from the case.
  • Be very careful not to puncture the battery when prying. Use blunt plastic tools.
  • The battery is removed.
  • Replace the battery with a new one.
6 autre(s) ont terminé cette réparation.
Eneider Colina
Membre depuis le 20/09/2013
1 415 Réputation
8 tutoriels rédigés
“Heat gun”is too vague. So is IR thermometer. What temperature to soften adhesive? How would I know if I was buying the right things?
Deep - Réponse
I’m not using a heat gun, it´s a hairdryer; on this case the hairdryer hardly exceeds the 60°C and that is enough to remove the battery. If you want to buy a heat gun you must be careful not to use more than 50 °
Eneider Colina - Réponse
Where do you suggest ordering a replacement battery from?
snack le - Réponse
you can search it on Amazon and buy directly from LG.
Eneider Colina -
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 68
Total : 3,740
