Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will lead you through removing the initial covering and the battery on the LG Optimus G Pro.
Pièces
Aucune pièce spécifiée.
  1. Make sure before you begin working on your device, that the device is not charging.
    • Make sure before you begin working on your device, that the device is not charging.
    • Once you have access to the phone, there is a small indent on the bottom left side. Use your fingernail or a plastic opening tool to pry from here and pull off the back casing.
  2. Le kit d'outils Essentiel
    Les outils les plus utiles dans notre kit le plus compact.
    J'achète
    J'achète
  3. Once you have properly removed the outer casing, the back should look as so.
    • Once you have properly removed the outer casing, the back should look as so.
    • To remove the battery, pull up from the red mark using your finger. The battery should come up at an angle, and easily be able to be removed.
    • Once the battery is removed you may safely proceed to the next step.
10 autre(s) ont terminé cette réparation.
Wesley Pate
Membre depuis le 25/09/2014
1 641 Réputation
7 tutoriels rédigés
Équipe
USF Tampa, Team 15-5, Remmell Fall 2014 Membre de l'équipe USF Tampa, Team 15-5, Remmell Fall 2014
USFT-REMMELL-F14S15G5
3 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 10
Total : 3,018
