Aller au contenu principal
LG Optimus L7 P705 Display Replacement
Ce dont vous avez besoin
  1. LG Optimus L7 P705 Display Replacement, Display: étape 1, image 1 de 2 LG Optimus L7 P705 Display Replacement, Display: étape 1, image 2 de 2
    • Use a plastic opening tool to gently pry the back cover away from the phone by inserting it into the seam around the edges.
    • Once the cover is off, remove the battery and SIM card.
  2. LG Optimus L7 P705 Display Replacement: étape 2, image 1 de 1
    • Using a Phillips #000 screwdriver, remove the twelve 3mm screws around the frame, including those near the SIM and SD card slots.
  3. LG Optimus L7 P705 Display Replacement: étape 3, image 1 de 1
    • Carefully remove the bottom plastic plate located around the charging port area.
  4. LG Optimus L7 P705 Display Replacement: étape 4, image 1 de 2 LG Optimus L7 P705 Display Replacement: étape 4, image 2 de 2
    • Insert a plastic opening tool along the seam of the phone’s frame and gently apply pressure to lift off the midframe cover.
  5. LG Optimus L7 P705 Display Replacement: étape 5, image 1 de 2 LG Optimus L7 P705 Display Replacement: étape 5, image 2 de 2
    • Flip the phone over so the screen is facing up.
    • Carefully lift and remove the glass screen (display) from the front of the device.
8 autres ont terminé cette réparation.
Craig Lashley
Membre depuis le 10/08/14
307 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 9-1, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 9-1, Leahy Fall 2014
USFT-LEAHY-F14S9G1
3 membres
5 tutoriels rédigés
2 commentaires de tutoriel
Great tutorial as always on ifixit. Just be mindful of the top clip holding the glass bevel as it can be tricky and is close to circuitry.
Sooty - Réponse
Im miles i great this ifixit i'm beginner
Omair Sarip -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 21
Total : 5,485
